Our customers might be experiencing service disruptions due to a global outage at Microsoft Azure. Our team is actively monitoring the situation and working to minimize the impact. Thank you for your patience and understanding.
Any way to change a decimal separator of a list?
felcunha
Hello all,
I'm using zone lists to feed a GDL object.
These lists use comma as decimal separator because this is the standard rule in France... like this :
LGT01 ; 02 ; Living  ;         6,35 ; Main
But, GDL doesn't recognize the comma as a separator and ignores all the decimals.
Does someone know if there's a way to change the way decimal separators are set in AC without having to change the global parameters in the OS system ?
Thanks in advance,
Felipe Ribeiro Cunha
AC 26, macOS Monterey
4 REPLIES 4
Unfortunately it is an OS setting and can't be controlled in Archicad itself.
But GDL does not need to recognise the decimal point as a separator.
It is a number and therefore has an integer and decimal component already.
If you are trying to convert the number to a string, then you set the number of decimal places that you want to use.
In your example the semi-colon (;) is the separator.
felcunha
Hello Barry,
Yes but I need to get the whole number for my calculations in my object.
In my example, I want to get the 6.35 value to make math operations. Therefore, GDL does not recognize the comma as the decimal separator and gets only the "6" number.
I'd like to find a way to convert the commas into dots otherwise than using complex GDL code. (and even then I don't know if I could easily do!!)
GDL will recognise the comma or point as the decimal point.
The problem may be that in the list you are getting the information from the 6,35 may actually be two numbers separated by a comma?
felcunha
No, I only get the integer numbers of it. I'll check what can be the problem... maybe a Mac OS issue??
