‎2019-03-20 02:59 PM
LGT01 ; 02 ; Living ; 6,35 ; MainBut, GDL doesn't recognize the comma as a separator and ignores all the decimals.
‎2019-03-21 02:08 AM
felcunha wrote:Unfortunately it is an OS setting and can't be controlled in Archicad itself.
Does someone know if there's a way to change the way decimal separators are set in AC without having to change the global parameters in the OS system ?
‎2019-03-21 10:55 AM
‎2019-03-22 02:08 AM
‎2019-03-22 08:32 AM
Barry wrote:No, I only get the integer numbers of it. I'll check what can be the problem... maybe a Mac OS issue??
GDL will recognise the comma or point as the decimal point.
The problem may be that in the list you are getting the information from the 6,35 may actually be two numbers separated by a comma?
