2010-01-14 11:30 AM
2010-01-14 09:05 PM
2010-01-14 09:23 PM
2010-01-14 09:53 PM
2010-01-15 08:47 AM
Piotr wrote:why is there no advantage in having Win 7 32 over XP 32? I thought the RAM issue has been solved from Vista onward (the fact that XP32 only recognised a maximum of 3.2 gb ram)
Little correction:
The XP mode can be installed in Ultimate and Pro versions of Win7..
and for such Apps like AC XP mode is unusable - due to the virualized S3 trio video card😉
AC 12 works ok in win7 BTW.
Win7 32 bit is out of a question IMHO - no advantages over XP, only win7 64 bit can be considered as an upgrade
Best Regards,
Piotr
2010-01-15 09:55 AM
ICEdevil wrote:No 32 bit OS but server ones (due to programmers trick) can utilize more than 4 GB of RAM. Why use 32 bit OS when the application can take as much as 2 or 3 GB or ram (trick again - "/3" or "/PAE" in XPs boot.ini) - the memeory chips are quite cheap now.
my current setup is XP64 and it's being a pain in the butt as it's constantly conflicting with the RAID array...
2010-01-15 09:58 AM
