ArchiCAD 21 crashes due (probably) to Roof Surfacer 21
Hello guys,
We've been having problems with our files when we use the Roof Surfacer 21 on the roofs. It crashes when we try to delete a roof that has been applied with this add-on, which is a dilemma since we use modules to change our roofs.
Is there a work around with this, or if possible a solution?
Thanks.
1 Reply 1
I am wondering if you are deleting the roof, leaving the surfacer object?
Yes, the attached object should delete as well, but I am wondering if this is what is causing the problem.
Does it still crash if you delete the accessory first or both the accessory and roof together?
