ArchiCAD - Illustrator interoperability
A colleague with whom I work and uses Adobe Illustrator cannot select elements (lines, fills, etc.) in PDFs that I save/publish in ArchiCAD. He has no difficulty editing PDFs from other sources. What gives? Thanks.
5 REPLIES 5
Erwin Edel
Try printing to Adobe PDF printer, maybe that will work?
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
runxel
Hero
He must first dissolve the generated clipping mask(s) for sure.
POSIWID – The Purpose Of a System Is What It Does /// Ā«Furthermore, I consider that Carth... yearly releases must be destroyedĀ»
If the suggested PDF tips below don't help... note that Illustrator can open DWG files... so you could always go that route...
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thanks, all. I just sent DWGs to my colleague to see if that may give better results. I resent the PDFs with "hairlines" checked, however, the issue appears to be some sort of "bounding box" or background that is attached to the PDF that accompanies the actual drawing, rendering it unusable. I have no experience with Illustrator, and he says it is a great deal of trouble for him to get rid of the "bounding box" issue.
runxel
Hero
Kenneth wrote:
... however, the issue appears to be some sort of "bounding box" or background that is attached to the PDF that accompanies the actual drawing, rendering it unusable. I have no experience with Illustrator, and he says it is a great deal of trouble for him to get rid of the "bounding box" issue.
No voodo magic here.
