2011-11-22 01:09 AM
2011-11-22 08:31 AM
diesellam wrote:Check your ifc-model generated in ArchiCAD in tekla BIMsight/Solibri Model Viewer/DDS first to check the quality. If it's ok then open in Revit. If you can share what's not retained to 100% you might get suggestions on alternative methods of modelling. Which versions do you use? Revit has a weaker ifc-implementation which you also should consider.
What's the best way to export ArchiCAD to Revit? (In terms of retain the 3d geomery).
I tried the IFC format and it's not 100% retained.
Any idea?
2011-11-22 09:36 PM
2011-11-23 11:53 PM
2011-11-23 11:54 PM
2011-11-28 07:21 AM
2011-11-28 06:00 PM
2011-11-28 06:41 PM
2011-11-28 06:52 PM
2011-11-28 10:41 PM
