Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
ArchiStair is ready!
Dear ArchiCAD users,
finally ArchiStair is ready and… FREE OF CHARGE!
Please get any info at www.archistair.com
Friendly
Fabrizio
In order to get info on the way you can receive your free ArchiStair please directly contact our sales manager sending her an e-mail at silvia.rallo@cigraph.com
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
168 Replies 168
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
"Maybe an option to either follow the raising line OR all the text should have the same angle and orientation as in step 1"
This can be easily achieved.
Let me summarize, two options:
1. it works as now (following the walking line)
2. enabling this option, all the text will behave like the first one (that one referring to the first step) that, of course, could be user customizable.
Could be ok in this way?
Friendly
Fabrizio
Fabrizio Diodati
Yes of course. (if i can customize the text on the first step that is even better.)
Thx Again
Djordje
oreopoulos wrote:
In drawing there is always a reading direction. You must read the drawing from one direction. AC does follow that rule.
In my school they taught that all the text on the sheet should be legible when seen from the lower right corner.
All the text in ArchiCAD does follow that, except the rotated dimensions 😉
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I guess they teach that too all schools
gpowless
Hi Folks,
While we're on this informative topic, can someone please tell me how to make the background fill in Archistair transparent? I love the product except sometimes I find the process of tweaking and fixing the stairs to be non-congruent...as if it was created by ten or 15 non-related people doing thier ~own thing~...if you know what I mean.
All help is much appreciated...
Thanks
Intel i7-6700@3.4GHz 16g
GeForce GTX 745 4g HP Pavilion 25xw
Windows 10 Archicad 26 USA Full
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
The background transparent issue has been implemented only in the last maintenance version.
You can get it from www.cigraph-store.com
Friendly
Fabrizio
Fabrizio Diodati
gpowless
Hi again,
When I do an update from within ArchiCad it says that the product is already up to date.....
Any ideas?
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Could you tell me which subrelease are you using?
Fabrizio Diodati
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
If you have the correct sub-release (the last one is 1.05), simply follow what the attached image shows in order to get a "transparent" stair 2D symbol.
Friendly
Fabrizio
Fabrizio Diodati
Hi
I am having a problem with ArchiStair in AC 9 , when I create a new stair using default information the stairs look fine, in both 2D & 3D. I then turn on rails in 2D the view it from story one or story two everything works great. The problem comes in when I try to offset the rails by -2" (as shown in the manual) stairs look fine on host story and 3D view. When I try to go up to the second floor AC locks up (stops responding). I tried ArchiStair on AC 8.1 no problems. I am using the latest updates of AC 9 and ArchiStair. Is there anyone else having this problem
Thanks in Advance
Darrel Ebanks
Tropical Home Designs
Cayman Islands
