Archicad 17 -Possible to have MEP Pipe/duct Schedule?
I want to have the schedule of showing the length of the duct/pipe. I attempt to set the criteria to be "Layer" & “pipe", and choose the fields to be "Layer" and Length". It is strange that the schedule only display the pipe with length of 1000mm.
Any idea for showing the length of the MEP pipe/duct?
10 REPLIES 10
David Maudlin
Kent:
If you open the Settings for one of the pipes, you will see that there is no Length or Width parameters, and that the Length is listed under the Parameters section. To get the length of pipes (and other MEP parts) you will need to use the Add Object Parameters button under Scheme Settings, then search for the pipe object and add its Length parameter to your schedule.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Wow. Great Tips! Thank you a lot!
David wrote:
Kent:
David
Foti
Hi David,
I followed the instructions for the pipe schedule, but was not able to find that paramater for the length, I got that length(A) only. I am in the right field? or location?
Foti
AC22 windows10
Foti B.
AC25
PC Precison 5760, Xeon 11955, 64GB, Nvidia RTX A3000
Foti
Never mind just got it.
Foti B.
AC25
Foti
One thing
I now have one layer in the schedule and that works, when I add a second layer to the field all the data gets removed?
Can I not put multiple layers on one schedule? I have my hot water distribution on one layer and cold on another. Or do I need to make a new schedule for each layer?
Thanks
Foti B.
AC25
David Maudlin
Foti:
You should post a screen shot of your Scheme Settings, but my guess is that you have "and" rather than "or" connecting the two Layer criteria.
David
Plus, you will have to put the two "Layer" criteria between parentheses so the Criteria are evaluated correctly.
