Archicad Plan To XML?
How to convert Archicad Plan to XML file? I need XML file with Archicad Plan object model (standart elemets, objects with parameters, coordinates).
I have read documentation and searched through internet.
My decision of this problem:
I will not use Archicad ODBC because of there are no coordinates parameters. I will use Archicad API to generate XML file. I can use DevKit Plan_Dump example.
There are no other abilities to get XML file of Archicad Plan.
Am I right?
1 Reply 1
Aaron Bourgoin
Subscribe to the Green Building Studio Site. Download the plug-in and the tutorial: http://www.greenbuildingstudio.com/
Install the add-on as per instructions. Follw the instructions some more for info on creating a project in GBS and referencing your ArchiCAD model to it.
The weather database is set up for the US only, so you'll need to select a location whose ZIP code you know (try Chicago 60609).
After submitting a project for a very prliminary energy analysis. you have the further option to create a gbXML file from the GBS web site.
I've tried this (twice - I'm no expert) and have imported the gbXML into another application - in my case IES <VE>
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.0 USA
Rhino 8.33 Mac
MacOS Tahoe 26.5.2
