import PDF document in Plotmaker layout
How to place/import PDF document in a Plotmaker layout? I try import but it only shows the icon of PDF. I try copy/paste but same thing happen. Thanks your help ahead.
14 Replies 14
TomWaltz
You can't.
Tom Waltz
Petros Ioannou
You have to use an external application such as adobe illustrator, where you can open the pdf and convert it to DXF/DWG and import it to plotaker.
I am not sure what happens with the scale of the drawing.
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
ya, I can only import DWG drawing. I was trying to import some manufacturer details. But when I import the DWG drawing, all the arrows are changed to lines. I thought it is much easier to paste a PDF instead...but no luck.
I'm certain there is a wish for PDF that you can vote for. Perhaps several. If I could vote multiple times, I would.
Rakela Raul
can you open it in photoshop, save as psd and import to pm ??
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
TomWaltz
There are a lot of programs out there that allow you to save a PDF as something else (JPG, TIFF, etc). Any of those formats can be imported to Archicad and Plotmaker.
At this time, there is no way to directly import a PDF 😞
Tom Waltz
TomWaltz wrote:
You can't.
Tom I hate to disagree but I have been importing PDFs into Plotmater for quite awhile. It comes in as OLE. It may not work on MAC platform. Do I get a mug for this one?
Gerald Hoffman
Archicad 4.55 - 29-Latest USA
Gerald wrote:
TomWaltz wrote:
You can't.
My only gripe with this is that Plotmaker doesn't drop the PDF extension when using the filename for a title, the way it does with, say, a PMK or TIF.
Acrobat Pro itself converts PDF to a variety of formats, such as TIF, PNG, etc., all of which work very well in PM.
Richard
AC26 (since AC6.0), Win10
Scott Bulmer
We have been importing pdf's into PM as well, however only single page documents. When we attempt to import a multi-page pdf document, only the first page imports. Is there a way to import multi-page pdf's into PM? Adobe Reader cannot save single pages at a time as far as I know, which would be an option.
Thanks,
Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
