2025-10-01 09:18 PM
Hello -
As a former AutoCAD user I am trying to figure out how best to transition. I have a project that I would like to half-do in Archicad while sill using primarily AutoCAD. I know I can use the "Xref" tool but his tool is complicated. All I want is to be able to have my autocad files as an underlay in a worksheet. The "import drawing tool" appears to be exactly what I want, except... When I import and the autocad file that I want to import has an attached "xref" both the AutoCAD files are imported - both the file I selected and the "xref". Am I correct in understanding that there is no way to tell archicad to exclude "xref"d file?? I understand I can turn off the layers in the Xref, but I am guessing(?) that this eats up memory? Perhaps this should be a wishlist..seems like it would be an easy add for archicad as it already asks for missing xref's
Thanks,
Operating system used: Windows 10
2025-10-02 02:25 AM
Can you open the DWG that has the XREFs in it, save it under a new name, delete the XREFs, and use this new DWG without the XREF data as the source of the Drawing you place?
2025-10-02 10:33 AM
Pretty sure that is works the same as when xref-ing a drawing containing another in AutoCAD. Just set the xref to Overlay if you do not want it to appear in subsiquent xrefs.
Ling.
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | i9 11900K | 32GB | GTX2080TI |
