Autocad into Archicad
I have a bunch of autocad plans I need to bring into Archicad9 can I use the layers or hatchs from autocad to buid my design in Archicad 9? Are there any shortcuts or "easy buttons" so to speak? Any advice would be appreciated!
5 Replies 5
Yes, there is!
It is File/Open or Ctrl+O!
TomWaltz
What have you tried? I would recommend the first step is looking at your user manual, which gives you at least a little bit of a starting point to see what's possible.
Tom Waltz
Djordje
kliment wrote:
Yes, there is!
No.
It is File Special/Merge with your template file open.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Link
I'll see your Merge and raise you an X-REF Management.
Link.
Djordje
He said opening, not XReffing 😉
Djordje
HP Omen
