Automatic Wall/Slab penetration In Archicad MEP
I am trying the Archicad MEP recently. I see from the offical website that there is automatic wall/slab penetration features in Archicad MEP. I am wondering how to use this feature as I do not see any material guiding the user on it. I would appreciate very much if any expert can tell me about it.
8 REPLIES 8
You can see the steps in the video on Automated Collision Detection here:
http://www.graphisoft.com/products/mep-modeler/
If you download the MEP installation package from here:
http://www.graphisoft.com/products/mep-modeler/MEP_downloads.html
and run it, the PDF documentation file for the MEP Modeler will be installed in your ArchiCAD>Documentation folder where it can be accessed directly, or from the ArchiCAD>Help menu.
AC 29 USA and earlier   â€¢   hardware key   â€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Karl, Thanks for your prompt reply.
I have watched the video regarding collision detection, however, it does not provide means to create any wall or slab opening for the MEP services to pass through.
I have also read the MEP User Guide. There is no topic related to Automatic Wall/Slab Penetration.
Sorry. I misunderstood and thought you were trying to detect the penetration (collision).
MEP does not provide for any automatic penetrations that I know of. Where did you see this on the web site?
Karl,
I see it at the following link.
http://www.graphisoft.com/community/press_zone/hvac.html
moming wrote:
Karl,
That is a 2001 article about an HVAC add-on.
MEP didn't come out till about 2008 (version 12) and although simmilar in some respects is a totally different add-on.
Too bad!
I thought that they were the same thing. Wonder why newer product has lesser feature. Have to give up Archicad MEP then.
Thank you to you all!
Erika Epstein
You can connect the MEP elements to the wall, slab or other element they penetrate with the SEO command which creates a hole.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
SO won't create distance from building elements... so only manual input 😕 This is crazy...
