Automating the backup schedule
Having read and re-read the Archicadwiki on Teamwork backup I still need a bit of help.
Here's our setup:
We are 100% Mac
We have a RAID protected NAS file server where we traditionally store all project files.
I have BIM Server running on my Mac Pro which is Time Machine protected.
I would like to be able to automate a cold database backup (i.e. the only guaranteed backup) to the NAS. We have Retrospect which I could automate to run the backup daily to the NAS, only replacing amended files.
However, I know almost nothing about automating scripts and I'm not sure how to get the recommended scripts to run at a scheduled time, i.e. stop the BIM server, retrospect does its thing, restart the BIM server.
Any thoughts appreciated.
6 Replies 6
Eduardo Rolon
Check SuperDuper!
http://www.shirt-pocket.com/SuperDuper/SuperDuperDescription.html
Easy to setup and schedule.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
We already have a backup software, Retrospect.
It is the script automation that I need.
Eduardo Rolon
Sorry, then I cannot help you since I use Superduper not Retrospect for my backups since I never could trust it.
AC29 US/INT -> AC08
another Moderator
I recommend Cronnix, I use it for sending scheduled MySQL backup emails. Should work for BIM Server purposes too.
CronniX is a Aqua frontend to the powerful Unix tool "cron".
Cron is a Unix system service that allows scheduled execution of scripts, programs, applications - in short anything that can be started from the command line. This includes OSX applications and AppleScripts.
Shell scripts for stopping and starting the BIM Server can be found here;
http://www.archicadwiki.com/Teamwork/Backup#A_cold_database_backup
Hope this helps.
Many thanks.
Do I just copy and paste the script shown on the wiki into the command section of Cronnix or do I need to make a text file with the file name shown in the wiki and then load that into Cronnix?
As an update I have now managed to solve the problem
The script needs to be run as the root user.
Using Cronnix I changed the current user to 'root' by typing it in. Do NOT use the system crontab.
I pasted the script text into a text file and saved as BIMStop.sh and BIMStart.sh
In finder I made the files executable in Terminal
I then enetred in the script box of Cronnix the following:
sudo sh /route/to/BIMStop.sh
This works a treat and stops the BIM Server. 15 minutes later, after a scheduled backup has run,
sudo sh /route/to/BIMstart.sh
restarts the server.
It should be noted that I could not get the script to properly shutdown the BIM server without the root/sudo element.
