BIMCollab changes FoV and cut surfaces - why!?
I have two issues in AC24 with BIMCollab 5.3 (BC)
1.
Why does BC changes my view cone (FOV, field of view) when I change camera position using BC issue double click:
Origina FOV 90:
After using BC, FoV 119?:
I always have to manually set back FOV to 90.
How can I avoid that?
2.
Cut elements get dark grey after using the zoom-to function from an issue.
Original view
After double clicking / zoom-to from issue manager issue in AC24:
Another thing is that changing camera position is much too slow.
Any other tip to speed that up? (We use selected only for view creation, max 20 elements, limit active layers to the max.)
Thanks for any hint/ tip!
BR, Florian
AC24 4018 INT, Win10, Quadro P2000, Xeon, BIMCloud
1 Reply 1
(I've moved this to the "Other Products" forum, since BIMCollab is not a GRAPHISOFT product.)
