gdford
BIMcloud as a Service - can not delete users
I am signed in as Admin to my BIMcloud as a service and for some reason i do not have a button in Users to delete users... I even created a new user not connected to a project and still there is no button to delete the user.
.... any thoughts anyone?
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
13 Replies 13
Are you a Server Admin or a Project Admin?
Are you trying to remove a User from a Project?
Or are you trying to remove a User from the BIMcloud server?
gdford
I am the Server Admin and Project Admin and I am trying to remove a user for the BIMcloud server.
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
gdford
that was "from the BIMcloud Server"
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
That is curious because as Server Admin you should have all the rights to be able to do that.
Can you post a few screenshots of the exact situation?
gdford
Yes - that was what I thought - I am logged in with my Graphisoft ID and I am the one who purchased and setup the server.
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
Hm, it is curious because I checked the BIMcloud User Guide and one Page 15 and Page 17 the "Delete User" command is visible on the user interface, but for some reason does not appear for you.
https://help.graphisoft.com/BCSAAS/INT/BCSAAS.pdf
I only see the "Enabled" command using which you can disable users I guess (I do not have BIMcloud installed on my machine).
I would recommend that you contact local support if no one here answers you. I have not used BIMcloud in a while so I can not offer you more help in this.
gdford
Is there anyway to tell if I am actually logged in as the Admin?
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
Check Page 7 of the User Guide, that may contain the answer to this question:
gdford
Thanks Laszlo - I bet i deleted myself - there had been two users with my name, but I don't remember seeing the Admin message under one of the them... I will get with my regional support.
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
