We value your input!
Building Material Property and string handling expressions
gdford
I am trying to use an expression to do basic string handling on the Building Material All property
SPLIT(Building Material, "-", 2)
also tried SPLITLEFT & RIGHT
this does not generate an error and it does not work.
Any Thoughts??
Thanks
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
8 REPLIES 8
Kevin Lee
As long as you choose "String" as the data type, shouldn't be a problem
Kevin Lee
Director of Technology | BIM
TZG Architects
@gdford could it be that your delimeter is set to 2? Meaning that it will split after the second “-“ that it finds? This would be display ‘CCC’ in the following building material: AAA - BBB - CCC.
If you wanted it to display BBB you would need to use SPLIT and set the delimiter to 1, or SPLITLEFT if you wanted AAA.
If it’s neither of the above, perhaps share a screenshot of your property expression and the building material name that you have set.
ARCHICAD 25 - Mac OS Monterey - MacBook Pro 2.3Ghz Quad-Core Intel Core i7 16gb DDR3
kmitotk
That expression only works with single Building Material elements. If you wanted to split and return a part of all BM names from multiple BM elements such as Composites then there's another way to do it.
Kei Mito
Architect | Graphisoft Certified BIM Manager
ArchiCAD 27 JPN USA & INT | Windows 10
Just by adding the rules as a sequence I assume?Screen Shot 2022-09-30 at 10.30.19 pm.png
gdford
Interesting - I will give that a look see.
Thanks!
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
yep - I tried setting it to 0, 1, and 2 - none of that works
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
SPLIT(Building Material ..... does not work - the other examples do work
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
kmitotk
Your expression [SPLIT(Building Material, "-", 2)] should work only when the element is made of a single building material, otherwise it wouldn't.
Kei Mito
