2022-11-02 02:34 AM - last edited on 2023-05-08 11:35 AM by Noemi Balogh
I downloaded a 3Dmodel part of a map in many different formats suitable for Archicad (dxf, etc), I have tried multiple times but for some odd reason The 3D model does not open as it appears that the layers happen to be missing, Please help!
2022-11-02 01:20 PM
Hi Zee,
I tend to use the skp files when using CADMapper. I then drag and drop and turn it into a morph afterwards. Otherwise when importing dxf's there should be an option to import the new layers into that project, or otherwise add the objects into the Archicad layer.
more here:
DXF-DWG Import Translator Settings - Graphisoft Community
Otherwise check your Partial Structure Display, Graphic overrides and so on. Sometimes it's all there, you just can't see it 😉
