Calculation with Modules
TomWaltz
Has anyone found a way to assign any kind of ID to a Module, so you could create a schedule of modules placed, or sort elements in a schedule by the module they occur in?
Tom Waltz
5 REPLIES 5
Hi Tom,
Offhand, I don't see a good/clean way, even with the API.
The EIDM knows about the host module, for example, but the IS doesn't. I don't see host module in the list scheme criteria, and it isn't something that is part of the SQL/ODBC tables either that I recall.
TomWaltz
Thanks, Karl
that's what I was afraid of. I was trying to get some kind of "unit schedule" put together, and maybe even some kind of Zone marker that could be used in a module, and read the ID of the module, so the room number could be different every time the module was placed.
I can't even guess where to start on that one! This one may have to be shelved until some later date (Archicad 10, 11, 12......)
Tom Waltz
Thanks for your confidence in my opinion, Tom 😉 but I don't pretend to know all... someone else may know a way! 😉
If it is indeed not possible (as it seems), it should be part of a major overhaul of the calculation functions in a future version.
Regards,
TomWaltz
I trust your opinion. Wasn't there some old Star Trek line about trusting Spock's guesses more than other people's facts?
I would think the only thing it would require would be to treat modules as an element type, which has a default settings menu that can accept parameters, such as ID. There kind of is one already which sets insertion height and master layer. Why not a few more?
Tom Waltz
Thanks, Tom.
Or... to treat modules as part of a hierarchy... IMHO layers should be able to be nested in a tree structure (particularly to accomodate modules and xrefs), and the elements of nested hotlinked modules might perhaps have ID strings that reflect the nesting (or optionally expose the base "leaves" if someone wants a flat element list). The EIDM and all Calculate functions should accomodate this kind of hierarchy (again IMHO).
Live long and prosper...
