Can AC general window list like this?
TYPE USER ID GROUND STORY 1ST STORY TOTAL
WINDOW C001 5 5 10
WINDOW C002 3 2 5
WINDOW C003 3 2 5
WINDOW C004 4 4 8
WINDOW C005 2 3 5
After study the help file of AC ,I find it's impossible to general window list directly from AC like above .I do know how to get window list by story but still need to do some work in EXCEL to achieve my desired window list .
Anybody can help?
5 REPLIES 5
Djordje
WINDOW C001 5 5 10
WINDOW C002 3 2 5
WINDOW C003 3 2 5
WINDOW C004 4 4 8
WINDOW C005 2 3 5
Anybody can help?
Which ArchiCAD?
If 8.1, did you try Interacive schedule?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I use ArchiCAD 8.31 and tried the Interacive schedule. The same result!
WINDOW	C001	5	5	10
WINDOW	C002	3	2	5
WINDOW	C003	3	2	5
WINDOW	C004	4	4	8
WINDOW	C005	2	3	5
Anybody can help?
So, you want the quantity subtotal by story and grand total on one line.
No, AFAIK, it is not possible to generate this kind of report within AC by using just IS or a list scheme. (You could do it - only as a theoretical point, but not a practical one - by using some strange GDL scripting and a temporary external file.)
AFAIK, the best way to produce this kind of thing is to export the quantity info from the list scheme (component or otherwise) or the I.S. and to process it in Excel or Access/Filemaker. You could write a script there to avoid the manual work.
Thanks the reply from AC masters .Now I would give up to achieve this in AC and told our local customers they only can get this kind of list from EXCEL .
Why you not force GS to improve AC?
