‎2010-01-28 05:09 PM
‎2010-01-28 05:46 PM
‎2010-01-28 05:47 PM
‎2010-01-28 06:41 PM
‎2010-01-28 10:06 PM
Erika wrote:What do you mean by the subtraction math? The element info does reflect the effects of the SEO. I have found all the maths needed can be done in the IS. The various phases of cut and fill have to be explicitly modeled in any case so all it needs to do is get the sums.
It won't do the Subtraction math, but if you just want some quick information that will do it.
‎2010-01-28 10:54 PM
‎2010-03-14 11:30 AM
‎2010-03-14 04:11 PM
Erika wrote:I get you. You want to do the operations and show the cut and fill calcs. This would be nice but rather tricky since the variations would be significant. One way to do it would be to model the cut, fill and balance. Probably more trouble than it's worth though.
Matthew,
Both ways, IS and element information will give the correct volume of the each site mesh.
I would like to learn how to include in IS the difference in volume between two sums. In this example it would give the excavated volume of earth.
‎2010-03-14 09:26 PM
‎2010-03-18 05:04 PM
