We've got to keep this topic running... there also a wishlist thread for a whole new Ceiling tool
Here.  I'm working with some people in my office to find the best way to convert.  Up until now, we have had to use a grid of beams, typically using the model view in the ceiling plan to only show the centerlines.  However, not only is that a slow painful process to draw those beams, but what do you do if you're trying to show real exposed beams with thickness in your ceiling plan?!
I am working on a file to try out different methods to compare in IFC/Revit:
1.  The beam method described above;
2.  Using the Curtain Wall tool horizontally (difficult to edit);
3.  Using slabs or roofs with boolean beam cutouts;
4.  Using a Ceiling Grid Slab Accessory (not sure where it came from);
5.  Using ManuBIM Ceiling Editor v2 from BIM-Components (haven't tried yet);
6.  Using slabs and play with material settings.
I will compare the difficulty in editing against the quality of Revit results and let you all know.  If anyone has more ideas, bring them on!
	Chuck Kottka
Orcutt Winslow
Phoenix, Arizona, USA
ArchiCAD 25 (since 4.5)
Macbook Pro 15" Touchbar OSX 10.15 Core i7 2.9GHz/16GB RAM/Radeon Pro560 4GB
