Citrix & SharePoint
Does someone know if I could use ArchiCAD 8.1 or 9 with Citrix and/or SharePoint. My office start to use this applications and we think is useless for AC and PM.
Thanks
Aaron Bourgoin
The use of ArchiCAD via an ASP set-up is a very rare thing indeed. When I first started looking into this I was told the only instances of this kind of set-up were in Sweden.
I was then surprised to learn that I had a client using ArchiCAD this way. They started with version 6.5 and that worked fine in the Citrix environment. Thigs went differently when they upgraded to 8.1.
You should confirm the following with your ArchiCAD support provider, but I believe this does work natively in ArchiCAD 9. I have a client using ArchiCAD 8.1 licenses distributed via an ASP using Citrix. We had to arrange for a special key from Graphisoft, but I recall being told that the customization wouldn't be necessary with 9.
If you have any questions e-mail me via PM
Think Like a Spec Writer
AC4.55 through 28 / USA AC27-6010 USA
Rhino 8 Mac
MacOS 15.2
Thank you Aaron, I will give this information to our technical support guy and see. We are moving to AC 9 in a couple of weeks, after that I will contact you.
Thanks again.
