Continue Existing Pipe (MEP Routing)
Most times I click "start routing" and then click inside the pipe and nothing happens; except the button changes to "Start Routing" again, which indicates something went wrong.. and I don't understand what went wrong.
No matter how many times I try it, it just won't continue on an existing pipe. It works to create a new pipe if I click somewhere else, though.
The only workaround I can do is to insert a Transition with same diameter in both ends; then the MEP Routing will work.
I'm going nuts, cause I just don't understand why;) Is there some way to see why it's failing?
Ok, might be something to do with some kind of grouping;) Testing..
gpowless
I have encountered that issue - mostly when I am adding to a sloped pipe. The fix seems to be to select the straight pipe tool and place a short section of pipe first and then I am able to continue using the routing tool.
Intel i7-6700@3.4GHz 16g
GeForce GTX 745 4g HP Pavilion 25xw
Windows 10 Archicad 26 USA Full
alemanda
Yes. That is my same experience.
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
