Continue Existing Pipe (MEP Routing)
Most times I click "start routing" and then click inside the pipe and nothing happens; except the button changes to "Start Routing" again, which indicates something went wrong.. and I don't understand what went wrong.
No matter how many times I try it, it just won't continue on an existing pipe. It works to create a new pipe if I click somewhere else, though.
The only workaround I can do is to insert a Transition with same diameter in both ends; then the MEP Routing will work.
I'm going nuts, cause I just don't understand why;) Is there some way to see why it's failing?
3 Replies 3
Ok, might be something to do with some kind of grouping;) Testing..
gpowless
I have encountered that issue - mostly when I am adding to a sloped pipe. The fix seems to be to select the straight pipe tool and place a short section of pipe first and then I am able to continue using the routing tool.
Intel i7-6700@3.4GHz 16g
GeForce GTX 745 4g HP Pavilion 25xw
Windows 10 Archicad 26 USA Full
alemanda
Yes. That is my same experience.
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
