Customizing Schedules?
Trying to create a custom Door Schedule through "Element Schedule Schemes". I can't figure out how to add additional custom text fields beyond the 3 they set up for you.
Also, followed a previous thread to hide (and not schedule) selected doors within the project. I changed the ID of the unwanted doors to '0' and set up the "Criteria" so that it read "Element type is door and element ID > 0" but the unwanted doors still show up in the schedule (with the old ID numbers)
Any ideas?
Thanks in advance-
4 REPLIES 4
Link
You can add user defined text by going to Additional Parameters... then selecting a library part, typical of the ones you are scheduling (eg. from the ArchiCAD Library 10). Then you can add the 'gs_list_custom' parameters to your schedule.
These are found under the 'Parameters for Listing' section of the Parametrs List, within each object's settings dialog.
To eliminate a specific ID you need to set the criteria to 'is not' - instead of '>'.
Link.
Thanks Link.
Back to Interactive Bliss.
-Dale
How do I customize the template layout of the 'door legend' and the 'window legend'?
Link
Open the schedule, to the left of the 'Header Options' button is an arrow on a grey bar. Click on the bar to show the Schedule Options. The available options for formatting are there in there in all their glory.
Unfortunately, there's not narly enough formatting options.
Link.
