Michal Forejt
DWG export issue with dimensions (wrong Z axis)
Hi all,
when I export DWG with translator set up to Match File Origin: Select "Survey Point", DWG is not flat, but dimensions are few hundred meters above the rest of the "lines and fills". If I set translator to use "Project origin", it is OK.
Does anyone else have this issue?
Thanks in advance
ArchiCAD 28
MacOS 15.5
MacBook Pro M4 Pro
4 Replies 4
Are you saying that Dimensions in the DWG file are at a level of a few hundred meters vertically? Can you post a few screenshot of how they look in Archicad and in the resulting DWG? Is the DWG saved from Layouts, I suppose? Can you also show the X,Y, Z coordinates of the Survey Point?
Michal Forejt
thanks for quick reply.
DWG is published from view. Below are some screenshots.
Snímek obrazovky 2025-07-07 v 8.25.48.pngSnímek obrazovky 2025-07-07 v 8.24.26.pngSnímek obrazovky 2025-07-07 v 8.27.59.pngSnímek obrazovky 2025-07-07 v 8.28.54.png
ArchiCAD 28
MacOS 15.5
MacBook Pro M4 Pro
Karel Landa
This is a problem connected with survey point setting.
If you set the "Nadmořská výška" in "Umístění" to zero, dwgs will be alright.
But I've tried my now and dimensions are alligned with the drawing.
Try to set the parameters in "Georeferenční parametry pro IFC" based on your survey point setting. Something like this:
From Archicad 17
MacBook Pro M1 Max
Michal Forejt
Setting "Nadmořská výška" in "Umístění" solves the problem with DWG, but would probably influence also IFC export etc. 😞
Following setting doesn't work either:
ArchiCAD 28
MacOS 15.5
MacBook Pro M4 Pro
