2018-10-16 03:55 PM
Solved! Go to Solution.
2018-10-16 04:01 PM
2018-10-16 04:01 PM
2018-10-16 04:02 PM
2018-10-16 08:35 PM
Erwin wrote:Thank you! I didnt pay attention to that right side window, its good to know I can copy attributes from a file to another this easy.
You can use Attribute Manager to copy back the layers. Make sure you use 'by index' so everything is completely back the way it was.
As long as you have a backup file or template that you used for the project to copy the settings over, you are fine.
