Dependent expressions
Ernest Atanasiu
Hello there,
In Archicad 22 is it possible to define a property which has a value dependent on another property?
For example: we have a Door Type Schedule where we join uniform items depending upon Type. If I select "Type A" for doors, it would be great to have other properties directly pick up this type and adjust accordingly.
I was looking at the IF ( Logical, ValueIfTrue, ValueIfFalse ) syntax but I don't get it.
Like this : IF "Type" is "A" than Value is "25", IfFalse Value is "10"
Can you help, please ?
arch. ernest atanasiu
AC 10-26 INT/GER/FR on Win 10/ Win 11
poco2013
Mentor
This is a common problem. The only solution is to 'chain' the expressions, as in:
IF ( Logical, ValueIfTrue, IF ( Logical, ValueIfTrue, IF ( Logical, ValueIfTrue, ValueIfFalse ) ) )
Basically placing a new 'if' statement within the 'FALSE' condition. The last 'FALSE" generally returns a 'N/A' or null string.
Gerry
Ernest Atanasiu
Obviously, after I posted the answer, I found the solution.
IF ( {Property:OPENINGS/Type} = "A", "ValueIfTrue", "ValueIfFalse " )
Now the problem still remains. I f I have more than 2 types, how do I organize the expression? The False value should return to a default in all cases but it doesn't since the first expression was already evaluated.
IF Type = A than Value= 01, ELSE = ?
If Type = B than Value = 02, ELSE = ?
If Type = C than Value = 03, ELSE = ?
poco2013
Mentor
Gerry
Ernest Atanasiu
You are a genius !
This really works and it's amazing! The possibilities are endless !
