Dimensions decimal number as superscript
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2022-04-06 04:21 PM
Hi
I'm wondering if there's a way to set dimensions properties in order to obtain a desired look as follows:
so instead of having this usual style of decimal dimensions:
it would be so much better if the dimensions could look like this (it would require less space) - i.e. decimal numbers would be written in a superscript manner:
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-04-06 04:36 PM
Sure.
In your dimension style you want to set as centimeter with no decimals and 1 for extra accuracy.
Don't forget to store it as a dimension style name so you can set that style for you views in the view map.
This will of course apply to all other dimension in that view.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Sure.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-04-06 04:59 PM
Thank you so much, works perfectly!!
