‎2010-12-07 11:56 PM
‎2010-12-12 03:00 PM
Wokka wrote:A (painful but) workable workaround:
Is there a way to sort the schedule to reference only a particular catagorie of zone or some other filter method??
‎2010-12-14 03:35 AM
‎2011-01-10 12:19 PM
‎2011-01-10 09:58 PM
‎2011-01-11 02:10 AM
‎2011-01-11 08:00 AM
‎2011-01-11 11:27 AM
‎2011-01-11 02:29 PM
KeesW wrote:Zone associations are not layer dependent. It wouldn't make much sense since the zone association needs to be persistent and layer states can change all the time.
Surely fire zones would be turned off so that only room zones with room numbers are included when door schedules are generated?
I'll try it when I get back to work next week.
‎2011-01-12 03:58 AM
Matthew wrote:Are you sure?
‎2011-01-12 04:32 AM
Barry wrote:You're right. I was referring to doors and windows specifically. I probably should have been more clear about that.Matthew wrote:Are you sure?
I have a text object with a moveable hotspot that shows the zone name of the zone that the hotspot is in.
If I add another zone (different name) in another layer then the object will switch to show the zone name depending which layer I have turned on.
If both ar on it seems to default to the first placed zone.
If I turn the layers of then no zone is detected at all.
I also notice just the other day when playing with exporting data to text files that zones in different layers will produce different outcomes depending which layer is active at the time the text file is generated.
