Door schedule list
How can I show in the detail of the door frame, the measurements in the door view in the door list? After defining all the parameters in the door tool for each door, it is awkwards that it can't be represented in a plan or list?
Thanks!
Mario
Windows XP
AC10
1 Reply 1
Eduardo Rolon
If I understand what you are asking.To show it in the floor plans turn on the Door's Dimension Marker and configure it to show the information that you need. Remember that this Marker display can be also controlled by the Model View Option settings.
If you want to create a schedule use use the Schedule option or check in your project map for the Lists and double click the one about doors to see an example.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
