If I understand what you are asking.To show it in the floor plans turn on the Door's Dimension Marker and configure it to show the information that you need. Remember that this Marker display can be also controlled by the Model View Option settings.
If you want to create a schedule use use the Schedule option or check in your project map for the Lists and double click the one about doors to see an example.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08Macbook Pro M1 Max 64GB ram, OS X 10.XX latest
another Moderator
