Doors Legend sélection
I'm truying to select windows on the plan to modifie them with the button on the top left corner. For some of my doors, the option is disable. What to do?
Tank you for your help.
Your plan is probably set to a different layer combination to the one set in the view that you opened the schedule with.
What I do is open the floor plan so you can see your doors.
Now open the schedule from the Project Map and not the View Map.
This will use the same setup as the plan and not those saved with the view in the View Map.
Those buttons should then be available for use.
7 REPLIES 7
Have you checked if your Groups are set to on?
HTH
Tank you Barry, it make sense. I will try it.
Look at my screenshot. I'm in the project map and stil the same.
HTH
Look at what it does every times I go to the door schedule. It aide stuff and put the slab pink.
It also change my layer setting to custom. Possibly he can not see the doors because they are hidden. Whatever from where I open the table, it's the same.
Finally I had to change "Custom" for "floor plans" in "Layer Combination" in the schedule.
I guess you haven't correctly understand the concepts of Project/View/Layout Map.
You can find help here: https://archicad-talk.graphisoft.com/viewtopic.php?f=13&t=68874#p306024
See if it can help.
