EXPORT-Publish to ONE dwg file
Not sure if this is a software glitch or i doing something wrong.
Somehow i am unable to publish plans to single dwg file with Archicad 21.
i was trying many times but without success . In previous versions, i used this tutorial as reminder (https://www.youtube.com/watch?v=dEUuTcTIHb4) and everything worked well.
I set translator to : Single dxf-dwg file but when i put drawings to folder there is no option as in previous wersions ,,Marge to one dwg file ``
Any sugestion?
1 Reply 1
Erwin Edel
Put the drawings in one folder in publisher and if you select that folder you can tick the 'merge' button.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
