Empty DWG when opening with AC23
I have a problem with opening any dwg in AC23 (commercial version). They are totally empty. But when I open the same file with AC22 (edu version) it is all right.
In this way I am not able to work with the AC23 version
Does anyone know a solution?
Best
Eszter
3 Replies 3
Brett Brown
Place the DWG as a drawing and then explode it
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
Try Changing your Renovation Filter to one that "Shows All".
I believe there is an issue where the DWG is set as "New" and it may not be showing in your current reno filter.
Thank you for all the thips! Renovation filter was a good idea, I did not check it before but it didn't tunr to be the solution.
Placing it as a drawing and exploding it actually worked.
Thanks a lot!!!
