7 hours ago
trying to send project information to the Engineer in a dwg format and he cannot use the information. He says it contains only the text and not any drawing work.
I did send all the files that Archicad created when saving as a dwg. Tried to explain how to relink xrefs back to the file but still he did not manage to open it up.
How do I fix this?
Thanks,
Kyriaki
Operating system used: Mac Intel-based
46m ago - last edited 41m ago
Try to create a new DWG translator. In Save options, select Paper Space with Full View’s content as the value from Save Layout into options and Single DXF/DWG file from Place Drawings into options. Then there are no XREFs to begin with.
For further info, see https://help.graphisoft.com/AC/26/INT/_AC26_Help/140_UserInterfaceDialogBoxes/140_UserInterfaceDialo...
