Export Fills in DWG
I'd like to export my plan drawing as a DWG. All the fills with curved edges are extremely simplified in the DWG. Does anybody know how to change the settings to keep the geometry of the fills in the DWG? I'm using AC13.
Thanks, Claudia
Can you show a screenshot?
Are you sure this is not a view setting in AutoCAD that makes them look like a polygonal approximation of the curves? AutoCAD has such settings.
Also, what happens if you open the saved DWG file with ArchiCAD. Are the curves simplified then too?
Hi Claudia,
In AutoCAD type "regen" and hit "enter". That should regenerate the view and the curved elements should appear correctly.
Hope that helps,
Adrian Tudoreanu
