License Delivery maintenance is expected to occur on Saturday, October 19, between 4 and 6 PM CEST. This may cause a short 60-minute outage in which license-related tasks: license key upload, download, update, SSA validation, access to the license pool may not function properly. We apologize for any inconvenience.
Export Objects from Vectorworks to ArchiCAD
ethanbodnar
Curious if anyone has any experience with this and would you would suggest as the ideal export / import formats?
I'm working on building out a project that was created in Vectorworks, and would like to be able to import out some of the more complex objects from the Vectorworks and import them into ArchiCAD.
Been playing around with a couple methods so far:
3DS Format
https://app-help.vectorworks.net/2018/eng/VW2018_Guide/Export/Exporting_in_3ds_Format_3D_only.htm
https://helpcenter.graphisoft.com/knowledgebase/25539/
OBJ Format
https://app-help.vectorworks.net/2018/eng/VW2018_Guide/Export/Exporting_OBJ__3D_only.htm
Also, just got the trial of Modelport which seems to be maybe the best option for this and long term (file size, clean models, most settings) for importing future SketchUp objects, etc.
https://archvista.com/modelport/
Thank you!
Archicad v26, MacBook Pro, MacOS 13 Ventura, AMD Radeon Pro 5500M 8GB, RAM 64GB, Non-SSA, Twinmotion User
4 REPLIES 4
The most obvious choice would be the IFC format. Both companies are committed to the Open BIM approach.
Have you tried saving an IFC from Vectorworks and opening that in Archicad?
ethanbodnar
Thanks Laszlo, let me play around with that, seems like the most solid path forward for getting the whole file over!
I guess just thinking I'd like to export a couple of the more complex objects (pergola for example) from VW into AC as their own individual objects, so could save them as objects in my AC library for future use with this project or other projects.
If you just want to export individual objects from Vectorworks and import them into Archicad, another possible route is to save them as a Revit Family (RFA) file. AFAIK, both software support it (for Archicad you may need to install the Add-On).
ethanbodnar
Oh good call, that seemed to work well, thanks so much for thinking through it!
