Hi there
I have a problem concerning export of a file.
I received a "template" DWG file with views and layouts according to a certain standard, I want to place the 2d elements on the views and layouts, but when I try to export it from archicad back to the original DWG format I seem to loose the views and lay-out structure of the original DWG.
I need to have the layer structure, the views and the lay-outs from the original DWG file when exporting it back to DWG from pln.
I hope someone can help here, thank you.
Please describe i reasonable detail (I´m not a super exporter)
This is acomplex issue, that's why you haven't got any answers yet.
However, most answers are to be found in the Archicad's Help menu. Read the DWG paragraphs in the Reference Guide and the Collaboration Guide.
