krab-El
Export format
I want to export my Layout to dwg file but there is only the pdf format option. Could you please help me solve this issue?
Thanks
1 Solution
David Maudlin
krab-El:
Select the Publisher Set (up one level), then click the Publishing Properties... button and select either Create a real folder structure or Create flat file structure, not Create a single file.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Go to post
2 Replies 2
David Maudlin
krab-El:
David
krab-El
Great. Thx
