Wokka
Export to DWG inconsistant
I'm having a lot of trouble trying to satisfy a AutoCad office I do a lot of documentation for due to some simple problems converting to DWG's.
When I do bathroom and Kitchen layout, I place the tile pattern down then add the various elements over the tiles, thus hidding the tile layout. A simple ArchiCad method. I have found that if I assign the right pens etc to the objects (R8.1+ only), if I save as a dwg then a similar output is achieved. If, however, I save from plotmaker (my preferred method of printing) I totally lose any of this hidden fill ability available in the ArchiCad export.
I really don't want to print/export directly from ArchiCad and I don't want to have to trace around my toilets
Anyone got any ideas/suggestions........?
Does R9 fix it? I've been told it's the same translator and will act the same.
Cheers
Warwick Lloyd-Martin
3 D E N V I R O N M E N T
http://www.3de.com.au
Windows 11 Pro 64bit
ArchiCad 4.55>27 AUS
Lumion 12.5/2023
D5 Render
7 Replies 7
wokka-
have you checked the display settings in PM to make sure you're not seeing all fills as transparent?
w
Wokka
Weston,
thanks for the idea but unfortunatly it didn't help, I'd already had it defaulted to 'Use fill's background colour'...but it was worth a try
Any other idea's. Anyone...........anyone?
Lumion 12.5/2023
D5 Render
__archiben
what if you use the 'wipe-out' pen (-1) for all of your background fills? it comes with its own problems, but might work in this case?
~/archiben
b e n _ f r o s t
Wokka
~/archiben,
Thanks for the idea. That's what I use in the ArchiCad export and it works fine but as soon as I save out of plotmaker it no longer works.
If anyone has a few minutes, could they test it on R9?
Cheers
Lumion 12.5/2023
D5 Render
__archiben
Wokka wrote:
~/archiben,
hmm - i found this elsewhere: "Fills with curved edges can not be translated into Wipeout since it can be only rectangular or polygonal." it also sounds as though this is an autodesk limitation. but:
it doesn't explain why you're getting what you expect out of archiCAD, but not from plotmaker . . . are you sure you're using fill pen -1 (the one that looks like a small TV) as your background fill pen?
[and what happens if you go the other route? i.e. use background fill pen 91 (white) and go the traditional route?
~/archiben
b e n _ f r o s t
Wokka
Ben,
Attached a few examples to look at.
This doesn't work out of ArchiCad or Plotmaker.
thanks for you interest!
Cheers
Lumion 12.5/2023
D5 Render
Wokka
And the equivilant Plotmaker/Publisher images.
Please also not that I have re-assigned pen 91 (white) to pen 255 (Autocad white).
Lumion 12.5/2023
D5 Render
