Exporting DWG's
We are trying to export a dwg from ArchiCAD 10 in a format that will match what our client wants. One of our big problems (there have been many) is that we have a number of layouts for diferent plan views etc & our client wants one dwg with everything in. Whatever we try we still seem to get a separate dwg file for each layout, even if single dwg is selected in the translator.
Is there any way to export multiple layouts from ArchiCAD to the paper space of a single dwg file with the model space present as well?
Since this is how AutoCAD users work how else do Graphisoft expect us to produce drawings?
11 REPLIES 11
Laura Yanoviak
mark.leslie wrote:
Ideally we want one dwg from multiple layouts.
This is just bad practice (The 8th rule of CAD: "Just because you can, doesn't mean you should").
Good rule!
I thought about the problem because we had a bit similar situation: the plan itself is huge, but was split on many A3 layouts - everytime after export client got a number of incomplete "model space" plan views.
My suggestion (but I've didn't checked it out yet on pratice) is to replace in each *.dwg file a block with incomplete model view to external reference to the complete model space view. Tricky, huh, but should work.
I understand why they asked for complete thing - it's the way civil engineers work - they need whole picture.
