2004-07-05 01:23 PM
2004-07-05 02:28 PM
paolapasino wrote:unfortunately not at the moment. it's on the wish list if i recall correctly, and something that graphisoft have needed to sort out for some time.
Is there a way to set the convertor so that it saves only the piece of file that is actually cropped in the layout?
2004-07-08 06:02 AM
2004-07-09 05:58 PM
Erika wrote:Not quite. The masking fill will create a "wipeout" in AutoCAD. If the wipeout is erased, all of the geometry that was behind the wipeout is revealed. The geometry is still being converted, it's just hidden behind the wipeout.
[The masking fill] is supposed to do just what you want, mask out the areas you do not want to convert to dwg.
2004-07-09 06:23 PM
2004-07-09 06:36 PM
Erika wrote:Good question. I would prefer that it eliminate the geometry it is masking, but that just doesn't seem to be the case. Any thoughts Djordje?
Is there a chance it should erase when converting to DWG or is this how graphisoft intended it to function?
2004-07-11 08:04 PM
Jay wrote:Not as yet, although I am nearing the final (whatever that might mean) setup for the conversion in the office ... Will report.Erika wrote:Good question. I would prefer that it eliminate the geometry it is masking, but that just doesn't seem to be the case. Any thoughts Djordje?
Jay wrote:I hope not ... your data are, though?
FYI: I'm going from ArchiCAD 8.1 R2C(2284) to Architectual Desktop 3.3
2005-02-02 04:56 AM
