‎2004-06-23 01:06 PM
‎2004-07-05 01:17 PM
‎2004-07-05 03:59 PM
another Moderator
‎2004-07-05 05:51 PM
ejrolon wrote:The parameter is a variable called tilemode; if 0 you are in modelspace, if 1 in paperspace. Type it on the command line, change and see. Zoom extents after that usually helps to see something
Remeber that Intellicad is compatible to AutoCAD R14 so in order to see the paperspace you have to type tilemode in the command line and change the parameter from 1 to 0 or 0 to 1 and that will take you to pspace and the drawing
‎2004-07-05 06:12 PM
another Moderator
