Exporting to DWG - Trick to export Bold cut lines does not work anymore. Why?
I have a little issue what I would like to figure out but first I need do describe the situation.
Correct me if I am wrong but as I know when you exporting to DWG AC won’t generate the bold cut lines. Because that in the AC 19 I developed a little workaround.
I used to place a huge column with specific attributes over the whole project. Then after I export to DWG it creates a hatch which I simply select and generate the boundaries.
I recently tried out AC 22 and used the same trick but the output is wrong. As you can see on the pictures the hatch does not surrounds the windows and doors anymore. I tried it with the same pln files and translators. This trick still works in AC 19 but in AC 22 simply not.
My questions are:
Which version of AC made the change which affects this trick? 20, 21 or 22?
Is it even affected by the AC version?
What is this change and is it possible to turn it off/alter or something?
1 Reply 1
...Additional pictures
