Failure of Exporting archicad file into Cinema 4D
Problem 1:
The add-on for exporting archicad to cinema 4d is installed. However no objects are shown by openning the exported ***.c4d in Cinema 4D. Could someone tell me what is the problem?
Software Information:
Archicad Education 13
Cinema 4D Release 11.5
Add-On Cinema 4D 11/11.5 add-on for ArchiCAD 13
Problem 2:
I simply save the file as **.3ds file. However there is also nothing showing in the 3dsmax.
Could someone give me clear advice? Thank you !
1 REPLY 1
Use better AC4D+ ArchiCAD add-on & Cinema 4D from http://dinnye.neobase.hu
