‎2005-09-08 08:58 AM
The wrote:This would interest many people in the discussion around MaxonForm.
Main Improvements in Revit Building 8.1:
Considering that it is just a point release, Revit Building 8.1 packs a surprising number of new features. To start with, it enhances the Building Maker functionality for conceptual design mentioned in the previous section by enabling the import of NURBS surfaces from other applications in the form of DWG or SAT files. These can be turned into mass objects in Building Maker, after which you can create roofs, walls, floors, and curtain systems from selected faces (see Figure 5-a). A separate but related ability is the creation of non-vertical walls from massing components, created within Revit Building or imported from other applications (see Figure 5-b). These non-vertical walls behave like the regular walls: you can place doors and windows in them; they can be joined to other walls; they appear properly cut in plan views; they are correctly listed in schedules; and they can be exported along with their information to ODBC and other formats. Considering that Revit Building lacks a good set of freeform modeling tools, these new capabilities make it easier to bring conceptual massing models created in other applications into Revit Building and convert them into building models rather than having to start from scratch.
http://www.aecbytes.com/review/RevitBuilding8.htm
‎2005-10-29 04:04 PM
and you never shut up about it either. still haven't.I do have that bad habbit
nd how much time did you save with those 5 simple productivity enhancements?A LOT. But 5 features cannot increase the version by one. Maybe call it 8.2 but not V9.
‎2005-10-30 08:22 PM
oreopoulos wrote:I agree here. But this is partly solved with the Solid Element Operators (which is missing a graphical "manager" dialog) and is probably closely related to some major conceptual decision from a long time ago, which clearly proposed to split up the building and it's walls floor by floor (which still is a valid choice, IMHO).
for example i have a big wall ,say 30 meters high, and then create 5 slabs at various heights. The slab does not cut the wall in section. I have to split the wall at various heights and ajust it. And now maintanance.
I want to move that wall. I have to move each part of that wall (now it is split) and if i want to edit the height of the slabs, i have to edit the walls again. Does that seem normal for a 20 year old program.
If i have a small project, then ok, two three walls, i will do them.
But if they are many. Its a nightmare.
‎2005-10-30 10:27 PM
stefan wrote:i actually believe that the marquee tool combined with solid element operations
The Revit parametrics indeed provide a usable solution to your problem.
‎2005-10-31 04:57 AM
Chazz wrote:Are you really sure of this?
Perhaps more importantly, they have an astronomical user base all lined up to migrate.
‎2005-10-31 05:18 AM
Chazz wrote:Read your CAD history books and try to filter out the marketing from the facts.
I think it's fair to say that Revit's aspiration (whether it has succeeded is perhaps debatable) is to focus on the relationship between building elements so that the model becomes more intelligent and less delicate when the inevitable revisions are needed. In other words: parametrics. Reveit basically takes everything that ArchiCad has done to date as rote. BIM is now old hat. Parametrics as applied to architecture is a revolutionary rather than evolutionary step and so far GS is an almost total no-show in this department (yes, the library parts are nice).
‎2005-10-31 08:42 AM
‎2005-10-31 01:28 PM
‎2005-10-31 05:33 PM
‎2005-10-31 06:12 PM
Djordje wrote:Am I sure? Well, yes. My assertion is simply that these users (and I'm talking only about architects and their ilk, not the billions of surveyors, mechanical engineers, etc using Autocad) are going to be much more predisposed to migrate to Revit than something called ArchiCAD (wait a minute, I've heard of that, it's from Russia, right?). That predisposition is all it takes. Having a single-vendor upgrade path is an incalculable advantage. Having the new product (Revit) maintain close ties to your old one -AutoCad- makes it that much more reassuring to the migratee.Chazz wrote:Are you really sure of this?
Why is the ADT then given free, why didn't the astronomical user base migrate already?
‎2005-10-31 09:22 PM
Djordje wrote:with the exception of the relationship between 'top-of-wall' and 'underside-of-story-above' i agree with djordje . . . but i will say that i think a development of the marquee tool combined with solid element operations will give archiCAD a far more efficient and
I sad this many times and will say it again - I do NOT believe a piece of software to control the relationships in the model. I want to work with the model, not to set the relationships or disable them. As Oreopulos said, changing walls to slab thickness is OK - what if I need a custom solution for each storey? Don't I have to go and re-define everything? How does that reflect to the rest of the model?
The VB (no, I am not using BIM) model is too precious to be left to the control of the software, and has to be controlled by us. We are trained and have the knowledge to do it. No programmer knows what relationships of my building's elements I want, nor can he.
