GEOREFERENCED PLANS
Mauro Correia
Hello to all!!
I have a problem, i need to export some plans to .dwg but they need to be georeferenced.
Of course i have the plan from the topographer and it is georeferenced, but, how to put it again (after i use it by xref in archicad, and after using it to make the project) in .dwg format without losing the georeference??
Thaks you all.
ArchiGIS. http://www.esri.com/software/arcgis/index.html
If you figure it out let us know. I can't do it. I have been adding the georeferences to my final .pdf's using the Geospatial Location Tool.
I think Acrobat 9 Pro Extended will produce georeferenced pdf files also.
