2022-01-18 03:56 PM - edited 2022-01-19 07:45 AM
Hi Community
Are there any known problems with graphics cards not mentioned in the list of recommended Graphics Cards tested with Archicad 25, as for example:
AMD Radeon Pro W5500 8GB
Nvidia GeForce RTX 3060 Ti 8GB ?
We want to optimize a custom PC (CPU AMD Ryzen 5 5600X, 32 GB RAM, Chipset Mainboard AMD B550)
with one of the Graphic Cards above for working at home.
Just to ensure, that Archicad will work with this hardware.
2022-01-19 03:23 AM
i think both GPUs will work fine. Archicad mostly use processor and ram.
2022-01-20 03:19 PM - edited 2022-04-27 01:57 PM
Archicad uses the GPU in many areas, it uses hardware acceleration in 2D (it can even used antialiasing in 2D as can be set in the Advanced Redraw Options page of the Work Environment Dialog)., and it uses the GPU in 3D extensively. And now, since Archicad 25 Update 2, the Redshift Rendering Engine uses the GPU exclusively. So it is important to have a high-performance GPU, especially for Redshift.
However, I agree that both those cards should provide enough performance for Archicad.
Regarding Redshift, you should check the recommended GPUs on Maxon's Redshift page:
https://www.maxon.net/en/requirements/redshift-requirements
Edit: April 27, 2022
Please note that Redshift currently works only with Nvidia GPUs on Windows, so AMD GPUs are not an option if you want to use Redshift in Archicad 25 Update 2 or later on Windows.
2022-01-21 02:33 AM
yes i also agree with you but its not stated which hardware Archicad is using in the advance redraw so i assume it would be processor and ram.🤔
for Redshift yes you would need a good GPU.
I found that my 5 year old 1080ti still can handle it though. 😊
2022-01-21 03:59 AM
Hardware acceleration is always done by the GPU. The page talks about redraw options which is a graphical thing so the graphics card (GPU) performs related tasks.
Regarding Redshift: I am simply saying what Maxon says and they clearly state on their page the recommended GPUs. I have not myself worked with Redshift yet so can not comment any more on those recommendations.
